Wat je nodig hebt
Start by unlocking the right locking latch.
Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
Unscrew the circled screws in green and red
Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
Lift the keyboard
Begin by spotting the dummy memory card.
Then, remove it and put it on your workplan.
Unscrew the screw circled in red
Pull out the M.2 SSD in the direction of the red arrows
Remove the screw circled in red
Lift up the hard drive
Remove the hard drive in the direction of the red arrows
Disconnect the two connectors marked in green
Remove the WLAN card
Press down on the two brackets boxed in red
Remove the RAM stick in the direction of the red arrows
Press with a screwdriver in the red circled area to spread the base of the battery
Remove the battery by holding the screwdriver down
Remove the two screw circled in red
Disconnect the connector boxed in green in the direction of the green arrow
Remove the fan by lifting it up
Lift the retaining flap off of the connector boxed in red.
Disconnect the connector boxed in red.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
