Wat je nodig hebt
Start by unlocking the right locking latch.
Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
Begin by spotting the dummy memory card.
Then, remove it and put it on your workplan.
Remove the two screw circled in red
Disconnect the connector boxed in green in the direction of the green arrow
Remove the fan by lifting it up
To reassemble your device, follow the instructions in reverse order
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
