Wat je nodig hebt
Start by unlocking the right locking latch.
Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
Begin by spotting the dummy memory card.
Then, remove it and put it on your workplan.
Press with a screwdriver in the red circled area to spread the base of the battery
Remove the battery by holding the screwdriver down
To reassemble your device follow the following instructions in reverse order
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
