Ga door naar hoofdinhoud
Deze vertaling geeft mogelijk niet de meest recente updates van de bronhandleiding weer. Help ons met het updaten van de vertaling of bekijk de bronhandleiding.
Upper case
Wat je nodig hebt
  1. Upper case, Remove the Screws: stap 1, afbeelding 1 van 1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. Upper case, Remove the Keyboard: stap 2, afbeelding 1 van 3 Upper case, Remove the Keyboard: stap 2, afbeelding 2 van 3 Upper case, Remove the Keyboard: stap 2, afbeelding 3 van 3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. Upper case, Remove Keyboard Connections: stap 3, afbeelding 1 van 3 Upper case, Remove Keyboard Connections: stap 3, afbeelding 2 van 3 Upper case, Remove Keyboard Connections: stap 3, afbeelding 3 van 3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. Upper case, Remove the upper screws: stap 4, afbeelding 1 van 2 Upper case, Remove the upper screws: stap 4, afbeelding 2 van 2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. Upper case, Remove the SSD: stap 5, afbeelding 1 van 3 Upper case, Remove the SSD: stap 5, afbeelding 2 van 3 Upper case, Remove the SSD: stap 5, afbeelding 3 van 3
    • Remove the screw holding in the ssd.
    • Carefully remove the SSD from the connector.
  6. Upper case, RAM (Memory): stap 6, afbeelding 1 van 3 Upper case, RAM (Memory): stap 6, afbeelding 2 van 3 Upper case, RAM (Memory): stap 6, afbeelding 3 van 3
    • Gently pull outwards on the clips to free the RAM stick.
    • Remove the RAM Stick from its slot.
  7. Upper case, Battery: stap 7, afbeelding 1 van 2 Upper case, Battery: stap 7, afbeelding 2 van 2
    • Remove the five Phillips screws securing the battery.
    • Unplug the power connector and lift the battery out in the direction of the arrows to remove it.
  8. Upper case, Motherboard: stap 8, afbeelding 1 van 3 Upper case, Motherboard: stap 8, afbeelding 2 van 3 Upper case, Motherboard: stap 8, afbeelding 3 van 3
    • Lift the retaining latch and unplug the ZIF cable found under the keyboard.
    • Disconnect the nine marked cables as detailed in the following steps.
    • Remove the four screws securing the motherboard to the case.
  9. Upper case, ZIF Connectors: stap 9, afbeelding 1 van 3 Upper case, ZIF Connectors: stap 9, afbeelding 2 van 3 Upper case, ZIF Connectors: stap 9, afbeelding 3 van 3
    • The cables with the blue reinforcing tabs are ZIF connectors that require you to lift the retaining lever before removing the cable.
  10. Upper case, SATA Cable: stap 10, afbeelding 1 van 3 Upper case, SATA Cable: stap 10, afbeelding 2 van 3 Upper case, SATA Cable: stap 10, afbeelding 3 van 3
    • Remove the SATA3 cable from the motherboard after disconnecting it.
  11. Upper case, Motherboard (continued): stap 11, afbeelding 1 van 2 Upper case, Motherboard (continued): stap 11, afbeelding 2 van 2
    • Don't forget to remove these cables.
  12. Upper case, Display Connector: stap 12, afbeelding 1 van 2 Upper case, Display Connector: stap 12, afbeelding 2 van 2
    • Note: The original instructions call for inserting your thumbnail firmly under the base of the display connector
    • However, the proper way to remove the display connector is to grasp the plastic strap on top of the connector and use it to pull the connector straight up.
  13. Upper case, Remove the Motherboard: stap 13, afbeelding 1 van 3 Upper case, Remove the Motherboard: stap 13, afbeelding 2 van 3 Upper case, Remove the Motherboard: stap 13, afbeelding 3 van 3
    • Once the screws have been removed, carefully lift the motherboard from the end indicated by the arrows.
    • Remember to disconnect the cables near the fan.
  14. Upper case, Motherboard (continued): stap 14, afbeelding 1 van 1
    • The motherboard has been successfully removed.
  15. Upper case, Speakers: stap 15, afbeelding 1 van 3 Upper case, Speakers: stap 15, afbeelding 2 van 3 Upper case, Speakers: stap 15, afbeelding 3 van 3
    • Remove the right speaker.
    • To remove the left speaker, first peel off the microphone/headset cable, then the adhesive strips.
  16. Upper case, Speaker/Fan/Headset connector: stap 16, afbeelding 1 van 3 Upper case, Speaker/Fan/Headset connector: stap 16, afbeelding 2 van 3 Upper case, Speaker/Fan/Headset connector: stap 16, afbeelding 3 van 3
    • Remove the left speaker.
    • Remove the two Phillips screws securing the CPU fan to the case and remove the fan.
    • Remove the two screws securing the audio connector board.
  17. Upper case, Headset and USB Boards: stap 17, afbeelding 1 van 3 Upper case, Headset and USB Boards: stap 17, afbeelding 2 van 3 Upper case, Headset and USB Boards: stap 17, afbeelding 3 van 3
    • Lift the audio board at the point indicated by the red arrow and slide it away from the chassis in the direction of the orange arrow.
    • Remove the Phillips screw securing the power connector board.
    • Lift out the USB connector board in the direction indicated by the arrows.
    • The ribbon cable is secured to the upper case with adhesive. It is not necessary to disconnect it from the USB board; just carefully peel the entire assembly from the case in the direction of the arrows.
  18. Upper case, DC Board and CMOS Battery: stap 18, afbeelding 1 van 3 Upper case, DC Board and CMOS Battery: stap 18, afbeelding 2 van 3 Upper case, DC Board and CMOS Battery: stap 18, afbeelding 3 van 3
    • Unplug the DC input board, remove the single Phillips screw securing it and remove it.
    • The DC power wires can remain in place.
    • The CMOS battery is secured to the case with adhesive. Simply peel it off to remove it.
  19. Upper case, LED Board / Touchpad Button Plate: stap 19, afbeelding 1 van 3 Upper case, LED Board / Touchpad Button Plate: stap 19, afbeelding 2 van 3 Upper case, LED Board / Touchpad Button Plate: stap 19, afbeelding 3 van 3
    • Remove the two screws holding the LED board on the chassis and remove it along with the ribbon cable.
    • No force is necessary; it is lightly adhered to the board and can easily be peeled off.
    • Remove the two screws securing the touchpad button plate.
  20. Upper case, Touchpad Button Board: stap 20, afbeelding 1 van 3 Upper case, Touchpad Button Board: stap 20, afbeelding 2 van 3 Upper case, Touchpad Button Board: stap 20, afbeelding 3 van 3
    • Lift the ZIF connector retaining tab and unplug the button cable on the right.
    • Grasp the LED board between the two cables.
    • Following the direction of the red arrow, peel the two cables from the case.
  21. Upper case, Cable Tapes / Hinge Screws: stap 21, afbeelding 1 van 3 Upper case, Cable Tapes / Hinge Screws: stap 21, afbeelding 2 van 3 Upper case, Cable Tapes / Hinge Screws: stap 21, afbeelding 3 van 3
    • Peel off the pieces of tape holding the cables onto the chassis.
    • Remove the six Phillips screws securing the hinges, three on each side.
  22. Upper case, Upper Case: stap 22, afbeelding 1 van 3 Upper case, Upper Case: stap 22, afbeelding 2 van 3 Upper case, Upper Case: stap 22, afbeelding 3 van 3
    • While holding down the display, lift the chassis up to about a 45 degree angle.
    • The case will slide out once there is sufficient clearance.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
94%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Felice Suglia
30.731 Reputatie
261 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 155
