Ga door naar hoofdinhoud
why! N131WU Battery Replacement
Wat je nodig hebt
  1. why! N131WU Battery Replacement, Remove the Screws: stap 1, afbeelding 1 van 1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. why! N131WU Battery Replacement, Remove the Keyboard: stap 2, afbeelding 1 van 3 why! N131WU Battery Replacement, Remove the Keyboard: stap 2, afbeelding 2 van 3 why! N131WU Battery Replacement, Remove the Keyboard: stap 2, afbeelding 3 van 3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. why! N131WU Battery Replacement, Remove Keyboard Connections: stap 3, afbeelding 1 van 3 why! N131WU Battery Replacement, Remove Keyboard Connections: stap 3, afbeelding 2 van 3 why! N131WU Battery Replacement, Remove Keyboard Connections: stap 3, afbeelding 3 van 3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. why! N131WU Battery Replacement, Remove the upper screws: stap 4, afbeelding 1 van 2 why! N131WU Battery Replacement, Remove the upper screws: stap 4, afbeelding 2 van 2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. why! N131WU Battery Replacement, Battery: stap 5, afbeelding 1 van 2 why! N131WU Battery Replacement, Battery: stap 5, afbeelding 2 van 2
    • Remove the five Phillips screws securing the battery.
    • Unplug the power connector and lift the battery out in the direction of the arrows to remove it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Felice Suglia
31.100 Reputatie
264 handleidingen geschreven
Één opmerking
Merci beaucoup, tutoriel très bien fait qui nous a beaucoup aidé !
La Puce A l'Oreille - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 333
