Ga door naar hoofdinhoud
uAttend bn6000 Speaker Replacement
Wat je nodig hebt
  1. uAttend bn6000 Speaker Replacement, Disassembly: stap 1, afbeelding 1 van 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Speaker Replacement, Speaker: stap 3, afbeelding 1 van 1
    • Remove the two 5mm PH #1 screws from the speaker assembly, by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
    • Remove the speaker assembly from the unit, by lifting the speaker up and away from the housing.
  4. uAttend bn6000 Speaker Replacement: stap 4, afbeelding 1 van 2 uAttend bn6000 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Remove the bundled cable carefully, by prying up on it with the plastic opening tool.
    • Carefully remove speaker from unit by pulling it up and away from housing.
Conclusie
abdullah sumait
419 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 103
