Ga door naar hoofdinhoud
Inleiding
The fingerprint scanner reads the fingerprint of the employee being scanned. This guide will show you how to remove and replace the fingerprint scanner. Be careful not to damage the glass screen scanner.
Onderdelen
Geen onderdelen opgegeven.
  1. uAttend bn6000 Fingerprint Replacement, Disassembly: stap 1, afbeelding 1 van 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Fingerprint Replacement: stap 2, afbeelding 1 van 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Fingerprint Replacement, Fingerprint: stap 3, afbeelding 1 van 3 uAttend bn6000 Fingerprint Replacement, Fingerprint: stap 3, afbeelding 2 van 3 uAttend bn6000 Fingerprint Replacement, Fingerprint: stap 3, afbeelding 3 van 3
    • Remove the two 7mm PH #1 screws from the fingerprint scanner mounting tab by rotating the screw driver counter clockwise, removing the screw from the housing completely.
    • Remove the fingerprint scanner assembly from the unit by lifting the scanner up and away from the unit housing.
  4. uAttend bn6000 Fingerprint Replacement: stap 4, afbeelding 1 van 3 uAttend bn6000 Fingerprint Replacement: stap 4, afbeelding 2 van 3 uAttend bn6000 Fingerprint Replacement: stap 4, afbeelding 3 van 3
    • Disconnect the ZIF connector, by using your fingernail to lift up on the small locking flap. Then pull the ribbon up and away, out of the connector.
Conclusie
To reassemble , follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
abdullah sumait
419 Reputatie
4 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 370
