Ga door naar hoofdinhoud
MacBook Pro 15" Retina Display Mid 2012 왼쪽 팬 교체
Waarschuwing: Je bewerkt een vooraf vereiste handleiding. Alle wijzigingen die je hierin maakt, beïnvloeden alle 37 handleidingen die deze stap bevatten.
Stap 2
MacBook Pro 15" Retina Display Mid 2012 Left Fan Replacement: stap 0, afbeelding 1 van 1
  • Remove the following three screws securing the left fan to the logic board:
  • One 4.4 mm T5 Torx screw with 2 mm collar
  • One 5.0 mm T5 Torx screw with 2 mm collar
  • One 3.9 mm T5 Wide Head Torx screw
  • When reinstalling the fan and its screws, don't fully torque the screws until you've first installed all of them loosely, so that the fan can move a little and position itself properly as you insert the screws into their threaded standoffs.
왼쪽 팬을 로직 보드에 고정하는 다음 나사 세 개를 풀어주세요:
2mm 칼라가 있는 4.4mm T5 Torx 나사 한 개
2mm 칼라가 있는 5.0mm T5 Torx 나사 한 개
3.9mm T5 와이드 헤드 톡스 나사 한 개
팬과 나사를 다시 설치할 때는 나사를 나사산 스탠드오프에 맞출 때 팬이 약간 움직여 올바르게 위치할 수 있도록 먼저 모든 나사를 느슨하게 설치할 때까지 나사를 완전히 조이지 마세요.
