Ga door naar hoofdinhoud
Waarschuwing: Je bewerkt een vooraf vereiste handleiding. Alle wijzigingen die je hierin maakt, beïnvloeden de handleiding die deze stap bevat.
Engels
Nederlands
Stap 1 vertalen
Stap 1
With plastic opening tool, take the display screen out of its socket by gently lifting each corner. Flip the screen up towards the Motherboard that it is still connected to. The screen is still connected. Using the spudger, gently lift the film underneath the display bracket to peel it off. Set aside.
  • With plastic opening tool, take the display screen out of its socket by gently lifting each corner. Flip the screen up towards the Motherboard that it is still connected to.
  • The screen is still connected.
  • Using the spudger, gently lift the film underneath the display bracket to peel it off. Set aside.
  • With the plastic opening tool, gently pry open metal display bracket to remove from the Motherboard.
  • Using fingernail, pry black tape up from zif socket to remove the partially attached display screen.
Vertaling hier toevoegen
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
