Ga door naar hoofdinhoud
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement
Waarschuwing: Je bewerkt een vooraf vereiste handleiding. Alle wijzigingen die je hierin maakt, beïnvloeden alle 48 handleidingen die deze stap bevatten.
Stap 24
iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: stap 0, afbeelding 1 van 2 iPad Mini 3 Wi-Fi LCD Shield Plate Replacement: stap 0, afbeelding 2 van 2
  • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
  • At the top of the iPad opposite the home button, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along all four edges.
  • If you encounter a significant amount of resistance, stop twisting. Leave the picks in place, reheat, and reapply the iOpener to the problem areas, and run a pick through the sticking point one more time.
Vertaling hier toevoegen
