Ga door naar hoofdinhoud
iMac Intel 21.5" EMC 2805 디스플레이 어셈블리 교체
Waarschuwing: Je bewerkt een vooraf vereiste handleiding. Alle wijzigingen die je hierin maakt, beïnvloeden alle 80 handleidingen die deze stap bevatten.
Stap 3
iMac Intel 21.5" EMC 2805 Display Assembly Replacement: stap 0, afbeelding 1 van 3 iMac Intel 21.5" EMC 2805 Display Assembly Replacement: stap 0, afbeelding 2 van 3 iMac Intel 21.5" EMC 2805 Display Assembly Replacement: stap 0, afbeelding 3 van 3
  • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
  • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
  • Run the tool up along the left side of the display.
피자용 칼 같은 도구를 사용하여—틈을 따라 굴리면, 폼 접착제 중앙을 자릅니다.
항상 자르는 휠 뒤에서 손잡이를 미세요. 당길 경우 휠이 핸들에서 빠질 수 있습니다.
디스플레이 왼편을 따라 도구를 위로 미세요.
