Ga door naar hoofdinhoud
MacBook Pro 14" 2021 스크린 교체
Stap 12
MacBook Pro 14" 2021 Screen Replacement, Remove some of the hinge screws: stap 0, afbeelding 1 van 2 MacBook Pro 14" 2021 Screen Replacement, Remove some of the hinge screws: stap 0, afbeelding 2 van 2
  • Use a T8 Torx driver to remove two 5.2 mm screws from each hinge (four screws total).
  • Each hinge has a third screw, which you should leave in place for now.
T8 Torx/톡스 드라이버를 사용하여 각 힌지에서 5.2mm 나사 두 개를 풀어주세요 (총 나사 네 개).
각 힌지에는 세 번째 나사가 있으며 지금은 제자리에 그냥 놔두세요.
-[title] Unfasten some of the hinge screws
+[title] Remove some of the hinge screws
[* red] Use a T8 Torx driver to remove two 5.2 mm screws from each hinge (four screws total).
[* icon_note] Each hinge has a third screw, which you should leave in place for now.
