Ga door naar hoofdinhoud
Stap 11
Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat sink. During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it. During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
  • Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle out from underneath the heat sink.
  • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
Retirez soigneusement l'ensemble antenne, tout en faisant passer le faisceau de câbles d'antenne sous le dissipateur thermique.
Lors du remontage, pincez délicatement le faisceau de câbles et faites-le passer sous le dissipateur thermique pour le positionner correctement. Si nécessaire, prenez vos outils pour le diriger, mais ne forcez pas dessus.
Je bijdragen zijn gelicenseerd onder de open source Creative Commons licentie.
