Ga door naar hoofdinhoud
MacBook Pro 13" Touch Bar Late 2016 하단 케이스 교체
Waarschuwing: Je bewerkt een vooraf vereiste handleiding. Alle wijzigingen die je hierin maakt, beïnvloeden alle 11 handleidingen die deze stap bevatten.
Stap 3
MacBook Pro 13" Touch Bar Late 2016 Lower Case Replacement, Separate the clips: stap 0, afbeelding 1 van 3 MacBook Pro 13" Touch Bar Late 2016 Lower Case Replacement, Separate the clips: stap 0, afbeelding 2 van 3 MacBook Pro 13" Touch Bar Late 2016 Lower Case Replacement, Separate the clips: stap 0, afbeelding 3 van 3
Separate the clips
  • Insert one corner of an opening pick into the space between the lower case and the chassis.
  • Slide the opening pick around the nearest corner and halfway up the side of the case.
  • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
여는 픽의 한쪽 모서리를 하단 케이스와 섀시사이의 틈에 넣으세요.
이렇게 하면 하단 케이스를 섀시에 고정하는 첫 번째 숨겨진 클립이 풀립니다. 클립이 풀리는 것을 느끼고 풀리는 소리도 들려야 합니다.
