Inleiding
This guide is an easy to follow, step-by-step walkthrough to remove and replace the speaker from the ring Indoor Cam. You might need to replace the speaker if it is faulty or there is no audio output at all.
As you will be working with electrical wires and components, make sure the device is not connected to power and use ESD-safe tools to avoid electrical injuries. Be sure to handle the motherboard delicately to avoid damaging the small electrical components as you will need to remove it to reach the speaker.
Wat je nodig hebt
Place the cam with the base facing towards you.
Loosen the 21.6 mm silver screw using a Phillips #1 screwdriver.
Remove the base from the rest of the camera.
Gently remove the three white leads from their sockets on the top of the motherboard.
