Ga door naar hoofdinhoud
removing the HP Elitebook 6930p Optical Drive
Wat je nodig hebt
  1. removing the HP Elitebook 6930p Optical Drive, Battery Removal: stap 1, afbeelding 1 van 3 removing the HP Elitebook 6930p Optical Drive, Battery Removal: stap 1, afbeelding 2 van 3 removing the HP Elitebook 6930p Optical Drive, Battery Removal: stap 1, afbeelding 3 van 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. removing the HP Elitebook 6930p Optical Drive, Optical Drive: stap 2, afbeelding 1 van 3 removing the HP Elitebook 6930p Optical Drive, Optical Drive: stap 2, afbeelding 2 van 3 removing the HP Elitebook 6930p Optical Drive, Optical Drive: stap 2, afbeelding 3 van 3
    • With the bottom of the laptop facing up and the front toward you locate and loosen the M2.5×9.0 captive screw holding the optical drive into the laptop.
    • Insert a flat-bladed screwdriver or similar tool into the optical drive tab access hole and press the tab to the left to release the optical drive from the computer
    • The optical drive will unlock and pop out of the side of the laptop. You are now able to temove the optical drive from the laptop.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Richdave
32.371 Reputatie
30 handleidingen geschreven
Master Techs Lid van Master Techs
Community
327 Leden
1.699 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 4,194
