Ga door naar hoofdinhoud
ionvac SmartClean V2 Motor Wheel Replacement
Wat je nodig hebt
  1. ionvac SmartClean V2 Motor Wheel Replacement, Shell (Top & Bottom): stap 1, afbeelding 1 van 2 ionvac SmartClean V2 Motor Wheel Replacement, Shell (Top & Bottom): stap 1, afbeelding 2 van 2
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
  2. ionvac SmartClean V2 Motor Wheel Replacement: stap 2, afbeelding 1 van 3 ionvac SmartClean V2 Motor Wheel Replacement: stap 2, afbeelding 2 van 3 ionvac SmartClean V2 Motor Wheel Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
    • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
    • Remove the rims from your ionvac and set them aside.
  3. ionvac SmartClean V2 Motor Wheel Replacement: stap 3, afbeelding 1 van 1
    • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
    • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
    • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
    • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
  4. ionvac SmartClean V2 Motor Wheel Replacement: stap 4, afbeelding 1 van 2 ionvac SmartClean V2 Motor Wheel Replacement: stap 4, afbeelding 2 van 2
    • Lift the top shell off carefully.
  5. ionvac SmartClean V2 Motor Wheel Replacement, Motor Wheel: stap 5, afbeelding 1 van 1
    • Remove the 3 screws securing the cable assembly housing on the outer side of the motor wheel frame labeled either R (right wheel) or L (left wheel).
    • Set the cable assembly housing to the side.
  6. ionvac SmartClean V2 Motor Wheel Replacement: stap 6, afbeelding 1 van 2 ionvac SmartClean V2 Motor Wheel Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the 3 screws securing the motor wheel frame.
    • Dislodge the wheel motor frame from the bottom shelf.
  7. ionvac SmartClean V2 Motor Wheel Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the cable attaching the motor wheel frame to the logic board.
  8. ionvac SmartClean V2 Motor Wheel Replacement: stap 8, afbeelding 1 van 2 ionvac SmartClean V2 Motor Wheel Replacement: stap 8, afbeelding 2 van 2
    • Carefully pull one end of the spring out of place to remove it from the motor wheel frame.
    • This will separate the motor wheel frame from the motor wheel assembly.
  9. ionvac SmartClean V2 Motor Wheel Replacement: stap 9, afbeelding 1 van 1
    • Unscrew the five screws from the motor wheel assembly.
  10. ionvac SmartClean V2 Motor Wheel Replacement: stap 10, afbeelding 1 van 2 ionvac SmartClean V2 Motor Wheel Replacement: stap 10, afbeelding 2 van 2
    • Gently lift the clip on the side to separate the casing and expose the white plastic gears.
  11. ionvac SmartClean V2 Motor Wheel Replacement: stap 11, afbeelding 1 van 1
    • Remove all but the largest gear to expose the silver screws and washers underneath.
    • Unscrew and remove the two silver screws along with each accompanying set of two washers.
    • Now you can remove the motor from the wheel assembly.
    • To clean the motor, use a soft cloth or alcohol wipe.
Conclusie
Andre
175 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 788
