Ga door naar hoofdinhoud
ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement
  1. ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement, Front Wheel (Swivel Caster): stap 1, afbeelding 1 van 1
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Flip your ionvac upside down so the wheels are pointed upwards.
  2. ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement: stap 2, afbeelding 1 van 2 ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement: stap 2, afbeelding 2 van 2
    • Using your thumb and forefinger, grip the flat sides of the wheel and pull it out.
    • If the wheel is stuck, you can use a spudger to pry the caster out.
    • When reinstalling, the wheel should click into place. Before restarting the ionvac, try spinning the wheel with your finger to test its movement.
Conclusie
Ruth Mekonnen
794 Reputatie
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 302
