Ga door naar hoofdinhoud
ionvac SmartClean V2 Bumper Sensor Replacement
Wat je nodig hebt
  1. ionvac SmartClean V2 Bumper Sensor Replacement, Shell (Top & Bottom): stap 1, afbeelding 1 van 2 ionvac SmartClean V2 Bumper Sensor Replacement, Shell (Top & Bottom): stap 1, afbeelding 2 van 2
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
  2. ionvac SmartClean V2 Bumper Sensor Replacement: stap 2, afbeelding 1 van 3 ionvac SmartClean V2 Bumper Sensor Replacement: stap 2, afbeelding 2 van 3 ionvac SmartClean V2 Bumper Sensor Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
    • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
    • Remove the rims from your ionvac and set them aside.
  3. ionvac SmartClean V2 Bumper Sensor Replacement: stap 3, afbeelding 1 van 1
    • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
    • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
    • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
    • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
  4. ionvac SmartClean V2 Bumper Sensor Replacement: stap 4, afbeelding 1 van 2 ionvac SmartClean V2 Bumper Sensor Replacement: stap 4, afbeelding 2 van 2
    • Lift the top shell off carefully.
  5. ionvac SmartClean V2 Bumper Sensor Replacement, Bumper Sensor: stap 5, afbeelding 1 van 3 ionvac SmartClean V2 Bumper Sensor Replacement, Bumper Sensor: stap 5, afbeelding 2 van 3 ionvac SmartClean V2 Bumper Sensor Replacement, Bumper Sensor: stap 5, afbeelding 3 van 3
    • Turn your ionvac so that the sensor and the metal bumper piece are facing forward.
    • Gently lift and remove the bumper for cleaning or replacement.
Conclusie
Ruth Mekonnen
767 Reputatie
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 35
Altijd: 289
