1. Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
    • Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
  2. Remove the battery cover by gently pushing inward on the arrow on the cover.
    • Remove the battery cover by gently pushing inward on the arrow on the cover.
    • While maintaining pressure push the cover upward.
    • Remove the Battery from the socket
    • When installing the battery take note of the signs displayed in the socket to determine which direction the negative and positive ends should be.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joe
291 Reputatie
2 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 3
Altijd: 199
