Ga door naar hoofdinhoud
iView-776TPCII Rear Panel Replacement
Wat je nodig hebt
  1. iView-776TPCII Rear Panel Replacement, Rear Panel: stap 1, afbeelding 1 van 3 iView-776TPCII Rear Panel Replacement, Rear Panel: stap 1, afbeelding 2 van 3 iView-776TPCII Rear Panel Replacement, Rear Panel: stap 1, afbeelding 3 van 3
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
  2. iView-776TPCII Rear Panel Replacement: stap 2, afbeelding 1 van 2 iView-776TPCII Rear Panel Replacement: stap 2, afbeelding 2 van 2
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
Conclusie
Jonathan Fenimore
251 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-2, Baechle Fall 2015 Lid van IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 12
Altijd: 326
