Ga door naar hoofdinhoud
iRobot looj 120 Rear Motor Replacement
Wat je nodig hebt
  1. iRobot looj 120 Rear Motor Replacement, Rear Motor: stap 1, afbeelding 1 van 1
    • Remove the four exterior screws
Conclusie
Joshua
631 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 2-5, Duarte Fall 2014 Lid van UMass Dartmouth, Team 2-5, Duarte Fall 2014
UMASSD-DUARTE-F14S2G5
3 Leden
7 handleidingen geschreven
Één opmerking
Yeah, to replace the motor just 4 screws and no parts required! Too easy, too easy to write an article that doesn’t help :( Is it just to sell a screwdriver? This would not improve your reputation. You’re wasting our time and wasting your time.
Description: Remove the 4 screws than anyone can see is a good start but did anyone been able to actualy open the body and access inside the box?
I do have an iRobot Looj 330. The body looks very similar to the other model in the range. There are 4 screws, yes but the body in 2 parts doesn’t open that easy. It’s waterproof, I believe there is a trick… Which?
Daniel B - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 249
