Ga door naar hoofdinhoud
iRobot Looj 120 Controller Buttons Replacement
Wat je nodig hebt
  1. iRobot Looj 120 Controller Buttons Replacement, Removing Screws: stap 1, afbeelding 1 van 1
    • Remove the four exterior screws located under controller and on the handle.
    • Remove the five screws shown, and then carefully remove top plate. Electrical components are attached to top plate.
  2. iRobot Looj 120 Controller Buttons Replacement, Locate Circuitry: stap 2, afbeelding 1 van 1
    • Disconnect circuit board from power leads, and install new circuit board.
  3. iRobot Looj 120 Controller Buttons Replacement, Remove Exterior Screws: stap 3, afbeelding 1 van 1
    • Remove the four exterior screws to gain access to inner components. These screws are located on the bottom of the controller and on the handle.
    • Remove the five interior screws to access the buttons.
  4. iRobot Looj 120 Controller Buttons Replacement, Accessing the Buttons: stap 4, afbeelding 1 van 1
    • Remove top plate carefully so that none of the electrical components are damaged.
    • Remove the broken button and insert the new button into the mounting hole.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lucas Otto
101 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-5, Duarte Fall 2014 Lid van UMass Dartmouth, Team 2-5, Duarte Fall 2014
UMASSD-DUARTE-F14S2G5
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 216
