Ga door naar hoofdinhoud
iRobot Roomba i7 Front Bumper Replacement
Wat je nodig hebt
  1. iRobot Roomba i7 Front Bumper Replacement, Front Bumper: stap 1, afbeelding 1 van 3 iRobot Roomba i7 Front Bumper Replacement, Front Bumper: stap 1, afbeelding 2 van 3 iRobot Roomba i7 Front Bumper Replacement, Front Bumper: stap 1, afbeelding 3 van 3
    • Flip the iRobot Roomba i7 so that the underside is facing upwards.
    • Using a Phillips #1 screwdriver, unscrew the 6.27mm screw in the center of the side brush.
    • Using a Phillips #1 screwdriver, unscrew the 5 screws surrounding the bottom cover of the Roomba
  2. iRobot Roomba i7 Front Bumper Replacement: stap 2, afbeelding 1 van 3 iRobot Roomba i7 Front Bumper Replacement: stap 2, afbeelding 2 van 3 iRobot Roomba i7 Front Bumper Replacement: stap 2, afbeelding 3 van 3
    • Use the Philips #1 screw driver to remove the ten, 4.17 mm screws on the dislodged Bumper
  3. iRobot Roomba i7 Front Bumper Replacement: stap 3, afbeelding 1 van 2 iRobot Roomba i7 Front Bumper Replacement: stap 3, afbeelding 2 van 2
    • Once removed, readjust the bumper into its appropriate placement.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
My roomba seems to be blind some tomes it starts and just keeps on running into the walls over and over again sometime i rebbot it and it works and other times it doesnt work i dont know what wrong with it. Its a roomba i7+ 3 years old.
John Flannery - Antwoord
My Roomba will run until it hits the wall and then runs backwards. Help
beverly vernon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 47
Afgelopen 30 dagen: 277
Altijd: 11,902
