Inleiding
Eventually, the bag in the iRobot Roomba S9 Plus home base will fill up and need to be replaced. When it does, this guide is here to help. Follow the instructions and your home base bag will be replaced in no time.
2 opmerkingen
what do you do if after you change the bag , the base says there is no bag? So I replaced the old bag after I pulled stuff out , still no change. now robot won’t work . On app it says end job stuck and all it did is move off base and turn around (after hit clean) help
Can we have a tear down of the base? The bag switch sometimes doesn't want to work properly. You can resolder a new switch or just solder a jumper so it always "senses" one. There's alot of screws, sensors, wires and a big motor. It helps to know where all the screws go.
