Ga door naar hoofdinhoud
iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement
  1. iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement, Home Base Vacuum Bag: stap 1, afbeelding 1 van 1
    • Open the vacuum bag container at the top of the home base.
  2. iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: stap 2, afbeelding 1 van 3 iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: stap 2, afbeelding 2 van 3 iRobot Roomba S9 Plus Home Base Vacuum Bag Replacement: stap 2, afbeelding 3 van 3
    • Grab the grey tab at the top of the bag and lift the bag straight out of the home base.
Conclusie
Charles D'Amico
223 Reputatie
2 handleidingen geschreven
Cal Poly, Team S18-G3, White Winter 2020 Lid van Cal Poly, Team S18-G3, White Winter 2020
CPSU-WHITE-W20S18G3
4 Leden
9 handleidingen geschreven
2 opmerkingen
what do you do if after you change the bag , the base says there is no bag? So I replaced the old bag after I pulled stuff out , still no change. now robot won’t work . On app it says end job stuck and all it did is move off base and turn around (after hit clean) help
shelleyandboys - Antwoord
Can we have a tear down of the base? The bag switch sometimes doesn't want to work properly. You can resolder a new switch or just solder a jumper so it always "senses" one. There's alot of screws, sensors, wires and a big motor. It helps to know where all the screws go.
ashimo0463 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 1,357
