Ga door naar hoofdinhoud
iRobot Roomba 891 Battery Replacement
Wat je nodig hebt
  1. iRobot Roomba 891 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 iRobot Roomba 891 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Start by flipping your Roomba onto its back on a flat surface.
    • Be sure not to close the side brush bristles in the battery door during reassembly as shown by the handy warning in the second photo.
  2. iRobot Roomba 891 Battery Replacement: stap 2, afbeelding 1 van 1
    • Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
    • These captive screws are not intended to be removed from the cover.
  3. iRobot Roomba 891 Battery Replacement: stap 3, afbeelding 1 van 3 iRobot Roomba 891 Battery Replacement: stap 3, afbeelding 2 van 3 iRobot Roomba 891 Battery Replacement: stap 3, afbeelding 3 van 3
    • Grasp the tabs on either side of the battery.
    • Remove the battery by pulling up on the tabs.
    • While you're here, check the battery contacts for corrosion or debris.
Conclusie
Één opmerking
justin i added a push pin to step 1
thomas Wilson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 822
