Ga door naar hoofdinhoud
iRobot Roomba 890 Charging Contacts Replacement
Wat je nodig hebt
  1. iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: stap 1, afbeelding 1 van 2 iRobot Roomba 890 Charging Contacts Replacement, Charging Contacts: stap 1, afbeelding 2 van 2
    • Use a Phillips #2 screwdriver to remove the 7.7 mm screw.
    • Remove the yellow brush head.
  2. iRobot Roomba 890 Charging Contacts Replacement: stap 2, afbeelding 1 van 1
    • Place the Roomba facedown, with its bottom facing you.
    • Use a Phillips #2 screwdriver to remove the two 11 mm screws.
  3. iRobot Roomba 890 Charging Contacts Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery plate.
    • Remove the battery by pulling directly up on the grey pull tabs.
  4. iRobot Roomba 890 Charging Contacts Replacement: stap 4, afbeelding 1 van 2 iRobot Roomba 890 Charging Contacts Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
    • Remove the bottom plate of the Roomba.
  5. iRobot Roomba 890 Charging Contacts Replacement: stap 5, afbeelding 1 van 2 iRobot Roomba 890 Charging Contacts Replacement: stap 5, afbeelding 2 van 2
    • Turn Roomba face up.
    • Remove the dustbin by pressing the release button on the top side of the Roomba and pulling it straight out.
  6. iRobot Roomba 890 Charging Contacts Replacement: stap 6, afbeelding 1 van 2 iRobot Roomba 890 Charging Contacts Replacement: stap 6, afbeelding 2 van 2
    • Using the opening tool, remove retaining band.
    • Use the removal tool to remove the face plate as well.
    • Pry up slowly around the edges to prevent damage to the plastic components.
  7. iRobot Roomba 890 Charging Contacts Replacement: stap 7, afbeelding 1 van 3 iRobot Roomba 890 Charging Contacts Replacement: stap 7, afbeelding 2 van 3 iRobot Roomba 890 Charging Contacts Replacement: stap 7, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handle screws.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Lift the top plate off.
  8. iRobot Roomba 890 Charging Contacts Replacement: stap 8, afbeelding 1 van 2 iRobot Roomba 890 Charging Contacts Replacement: stap 8, afbeelding 2 van 2
    • Locate the charging contact wire connection to the motherboard.
    • Release the connector.
    • Pull gently on the white plug, not the wires themselves.
  9. iRobot Roomba 890 Charging Contacts Replacement: stap 9, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the four 9.3 mm bumper sensor screws.
  10. iRobot Roomba 890 Charging Contacts Replacement: stap 10, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the two 9.3 mm screws holding the charging contact backings in place.
    • Remove the charging contact backings.
  11. iRobot Roomba 890 Charging Contacts Replacement: stap 11, afbeelding 1 van 1
    • Use the iFixit opening tool to gently pry down on the charging contact, on the side closest to the cliff sensor.
    • With the charging contact dislodged, pull it through the Roomba housing.
Conclusie
Devin Steiblin
442 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-3, Petersen Spring 2022 Lid van UMass Dartmouth, Team 1-3, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G3
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 156
Altijd: 4,162
