Ga door naar hoofdinhoud
iRobot Roomba 880 Battery Replacement
Wat je nodig hebt
  1. iRobot Roomba 880 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 iRobot Roomba 880 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Start with your Roomba upside down, with the wheels facing up.
    • Using a JIS driver in #1 size remove the two 15mm screws holding the battery cover in place.
  2. iRobot Roomba 880 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery cover and place it off to the side.
  3. iRobot Roomba 880 Battery Replacement: stap 3, afbeelding 1 van 2 iRobot Roomba 880 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the battery using the green tabs on either side of the battery.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Frances Belcher
420 Reputatie
2 handleidingen geschreven
Cal Poly, Team S17-G4, Banghart Spring 2017 Lid van Cal Poly, Team S17-G4, Banghart Spring 2017
CPSU-BANGHART-S17S17G4
5 Leden
5 handleidingen geschreven
Één opmerking
I am not trying to be negative here, but if someone needed this guide to understand that a bad battery needed to be replaced, shouldn’t you put that they would need a new battery? According to your directions, they do not need a new battery. As a result, they are going to take out their battery, and put the old one back in. The problem remains. I have never written a guide, so maybe you can only choose parts from iFixit and that is why you did not have one listed in the parts needed, but I would have thought it would have been in the directions.
Anyhow, the guide is still appreciated… please consider this only as constructive feedback to help enhance the product.
Nathan Kramer - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 38
Altijd: 4,627
