Ga door naar hoofdinhoud
iRobot Roomba 870 Battery Replacement
Wat je nodig hebt
  1. iRobot Roomba 870 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 iRobot Roomba 870 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • To access the iRobot Roomba 870 battery pack, first flip the Roomba upside down.
    • Then find the battery pack cover that is located in the space between the caster wheel, side brush, and vacuum.
    • Use a Phillips #0 screwdriver to remove the two 3.5mm screws on the battery pack cover.
  2. iRobot Roomba 870 Battery Replacement: stap 2, afbeelding 1 van 3 iRobot Roomba 870 Battery Replacement: stap 2, afbeelding 2 van 3 iRobot Roomba 870 Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove the loose battery cover to access the battery compartment.
    • Use the yellow tabs, located on the short ends of the battery pack, to gently pull the battery up and out of its slot.
Conclusie
Follow the steps in reverse order for reassembly.
Vitek Harvey
149 Reputatie
1 Handleiding geschreven
Cal Poly, Team S14-G3, Banghart Spring 2017 Lid van Cal Poly, Team S14-G3, Banghart Spring 2017
CPSU-BANGHART-S17S14G3
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 3,350
