Ga door naar hoofdinhoud
iRobot Roomba 860 Filter Replacement
  1. iRobot Roomba 860 Filter Replacement, Filter: stap 1, afbeelding 1 van 3 iRobot Roomba 860 Filter Replacement, Filter: stap 1, afbeelding 2 van 3 iRobot Roomba 860 Filter Replacement, Filter: stap 1, afbeelding 3 van 3
    • Orient the Roomba so that the device is on its wheels and the words can be read from left to right.
    • Press the large button on the Roomba that is located closest to you.
    • Pull towards you to remove dust bin.
    • Now place dust bin flat with the large button towards you.
  2. iRobot Roomba 860 Filter Replacement: stap 2, afbeelding 1 van 2 iRobot Roomba 860 Filter Replacement: stap 2, afbeelding 2 van 2
    • With the dust bin completely detached from the Roomba, press the tab that is located on your right.
    • Now lift red plastic cover to begin removing the filter.
  3. iRobot Roomba 860 Filter Replacement: stap 3, afbeelding 1 van 2 iRobot Roomba 860 Filter Replacement: stap 3, afbeelding 2 van 2
    • Using the yellow ribbon that is located at the top of the filter, pull it towards you.
    • Carefully remove the used filter.
Conclusie
Stephen Yezukevicz
193 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G5, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G5
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 297
