Ga door naar hoofdinhoud
iRobot Roomba 655 Pet Series Internal Faceplate Removal
Wat je nodig hebt
  1. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Face Plate: stap 1, afbeelding 1 van 2 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Face Plate: stap 1, afbeelding 2 van 2
    • Remove the dust bin by pushing on the button for the dust bin removal
    • Pull the dust bin out
  2. iRobot Roomba 655 Pet Series Internal Faceplate Removal: stap 2, afbeelding 1 van 2 iRobot Roomba 655 Pet Series Internal Faceplate Removal: stap 2, afbeelding 2 van 2
    • Pull up on the silver handle to release the top protectant plastic
    • Remove the top plastic carefully
  3. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Bumper: stap 3, afbeelding 1 van 2 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Front Bumper: stap 3, afbeelding 2 van 2
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  4. iRobot Roomba 655 Pet Series Internal Faceplate Removal: stap 4, afbeelding 1 van 3 iRobot Roomba 655 Pet Series Internal Faceplate Removal: stap 4, afbeelding 2 van 3 iRobot Roomba 655 Pet Series Internal Faceplate Removal: stap 4, afbeelding 3 van 3
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
  5. iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: stap 5, afbeelding 1 van 3 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: stap 5, afbeelding 2 van 3 iRobot Roomba 655 Pet Series Internal Faceplate Removal, Internal Faceplate: stap 5, afbeelding 3 van 3
    • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
    • Use your Phillips head #0 to remove the one - 7mm bottom center screw
    • Use your Phillips head #2 to remove the two - 8mm screws by the handle
    • Push down the two release points to pull the plastic piece up
    • Pull the plastic piece up
Conclusie
Rhett
1.329 Reputatie
7 handleidingen geschreven
Cal Poly, Team 21-20, Maness Winter 2015 Lid van Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 734
