Ga door naar hoofdinhoud
Inleiding
You will be removing the front bumper (this runs into objects and walls) from the Roomba to gain access to the control center (display) and motherboard.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver. Pull the plastic bumper protector up and off of the bumper.
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  2. Flip the Roomba back over, so you are viewing the top. Pull up on the front bumper to remove it. Be careful not to pull too hard because there is wiring attached to the bumper.
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
Conclusie
Rhett
1.250 Reputatie
7 handleidingen geschreven
Cal Poly, Team 21-20, Maness Winter 2015 Lid van Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Leden
14 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 38
Altijd: 2,564
