Ga door naar hoofdinhoud
iRobot Roomba 655 Pet Series Drive Wheels Replacement
Wat je nodig hebt
  1. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: stap 1, afbeelding 1 van 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Side Brush: stap 1, afbeelding 2 van 2
    • Flip the device over onto its back.
    • Find the side brush, and unscrew the single screw that connects to brush motor by using the Phillips head #2 screwdriver.
    • This screw doesn't completely come out of the yellow side brush.
  2. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: stap 2, afbeelding 1 van 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Back Panel: stap 2, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the four screws on the back panel.
    • Once the screws are loose gently pry the back plate away from the body by using the spudger tool.
    • The screws don't completely come out of the panel, but it will still come apart once unscrewed.
  3. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: stap 3, afbeelding 1 van 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: stap 3, afbeelding 2 van 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Removing the Battery: stap 3, afbeelding 3 van 3
    • Grab the two pieces of green tape with your thumb and index finger
    • Pull up on the battery in an upwards direction to remove it
  4. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: stap 4, afbeelding 1 van 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Battery Contact Points: stap 4, afbeelding 2 van 2
    • These are the contact points on the Roomba for the battery
    • These are the contact points on the battery
    • If these contact points are dirty, they can be cleaned with a moist microfiber cloth (distilled water recommended)
  5. iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: stap 5, afbeelding 1 van 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: stap 5, afbeelding 2 van 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement, Drive Wheels: stap 5, afbeelding 3 van 3
    • Remove the three screws with your Phillips head #1, holding the drive wheels in place
    • These three screws will stay in place and won't come out of the plastic
  6. iRobot Roomba 655 Pet Series Drive Wheels Replacement: stap 6, afbeelding 1 van 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement: stap 6, afbeelding 2 van 3 iRobot Roomba 655 Pet Series Drive Wheels Replacement: stap 6, afbeelding 3 van 3
    • Unscrew the actual wheel from the blue plastic holder
    • Pull apart the blue holder to completely remove the wheel
  7. iRobot Roomba 655 Pet Series Drive Wheels Replacement: stap 7, afbeelding 1 van 2 iRobot Roomba 655 Pet Series Drive Wheels Replacement: stap 7, afbeelding 2 van 2
    • To go further into the holder to access the programming chips you can unscrew these compartments
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Rhett
1.329 Reputatie
7 handleidingen geschreven
Cal Poly, Team 21-20, Maness Winter 2015 Lid van Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 19
Altijd: 2,286
