Ga door naar hoofdinhoud
Inleiding
This is when things start to get a little more tricky. Start to be more careful because everything you are dealing with is attached to your motherboard from here on out.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the dust bin by pushing on the button for the dust bin removal Pull the dust bin out
    • Remove the dust bin by pushing on the button for the dust bin removal
    • Pull the dust bin out
  2. Pull up on the silver handle to release the top protectant plastic Remove the top plastic carefully
    • Pull up on the silver handle to release the top protectant plastic
    • Remove the top plastic carefully
  3. Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver. Pull the plastic bumper protector up and off of the bumper.
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  4. Flip the Roomba back over, so you are viewing the top. Pull up on the front bumper to remove it. Be careful not to pull too hard because there is wiring attached to the bumper.
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
  5. The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them Use your Phillips head #0 to remove the one - 7mm bottom center screw Use your Phillips head #2 to remove the two - 8mm screws by the handle
    • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
    • Use your Phillips head #0 to remove the one - 7mm bottom center screw
    • Use your Phillips head #2 to remove the two - 8mm screws by the handle
    • Push down the two release points to pull the plastic piece up
    • Pull the plastic piece up
  6. Pull the silver tab, and clear tinted display off Remove the 4 - 9mm  screws holding the display with your Phillips head #0 Remove the 4 - 9mm  screws holding the display with your Phillips head #0
    • Pull the silver tab, and clear tinted display off
    • Remove the 4 - 9mm screws holding the display with your Phillips head #0
  7. Remove the display Remove the plastic protectant film from the motherboard Remove the plastic protectant film from the motherboard
    • Remove the display
    • Remove the plastic protectant film from the motherboard
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Rhett
1.250 Reputatie
7 handleidingen geschreven
Cal Poly, Team 21-20, Maness Winter 2015 Lid van Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Leden
14 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 653
