Ga door naar hoofdinhoud
iRobot Roomba 650 Side Brush and Bottom Panel Replacement
Wat je nodig hebt
  1. iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Removing the Side Brush: stap 1, afbeelding 1 van 2 iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Removing the Side Brush: stap 1, afbeelding 2 van 2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Bottom Panel Removal: stap 2, afbeelding 1 van 2 iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Bottom Panel Removal: stap 2, afbeelding 2 van 2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Charles Ward
975 Reputatie
3 handleidingen geschreven
Cal Poly, Team 19-7, Maness Winter 2015 Lid van Cal Poly, Team 19-7, Maness Winter 2015
CPSU-MANESS-W15S19G7
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 18
Altijd: 4,533
