Inleiding
This will involve getting deep into Roomba's inner core and removing the motherboard. The IR transmitter is a small blue device housed in a black plastic casing towards the front of the Roomba. This infrared sensor helps the Roomba to locate itself and detect its surroundings.
Wat je nodig hebt
With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
Set the screw aside and pull the brush out.
Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
Once the side brush and bottom panel are out of the way, simply grasp the battery by the two green flaps and pull it out.
Remove the front bumper. You may remove it with your hands or a tool. It should snap off with some effort. It will still be attached to the Roomba by a couple of wires.
4 andere personen hebben deze handleiding voltooid.
Één opmerking
Hi, I am curious about this given what my 650 is doing... It turns on and runs for 2 minutes before I get the error about cleaning the wheels. Basically, the Roomba goes in a circle to the left and that's it. Occasionally, it will back up to the right, and then go in a faster circle to the left. If I hit the bumper it will go back to the right and then forward again to the left. I replaced the left wheel and it had no impact. Do you think it's the sensor? Thanks
