Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide explains how to quickly remove the side brush from your Roomba in order to either replace it or to further disassemble the device.
Onderdelen
Geen onderdelen opgegeven.
  1. Place your Roomba upside-down on a hard surface.
    • Place your Roomba upside-down on a hard surface.
  2. While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Gently pull upwards on the brush to remove it.
    • Gently pull upwards on the brush to remove it.
Conclusie
Aaron Jacobs
534 Reputatie
4 handleidingen geschreven
Cal Poly, Team 13-14, Regan Winter 2014 Lid van Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Leden
19 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 310
