Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Rotate the Roomba upside-down so the bottom is facing towards you.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Use a Phillips #1 screwdriver to remove the two captive mounting screws on the side wheel motor assembly.
