Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Rotate the Roomba upside-down so the bottom is facing towards you.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
Flip the Roomba over, grasp the bumper, and gently lift to remove.
Remove the two 5mm screws located near the center of the bumper using a Phillips #1 screwdriver.
Flip the bumper over and lift the sensor from its compartment.
You are now free to replace the bumper sensor.
4 andere personen hebben deze handleiding voltooid.
