Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Rotate the Roomba upside-down so the bottom is facing towards you.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Pinch the yellow tabs on the sides of the brush cage and lift up to open.
2 opmerkingen
Should be no need to remove the back plate. Just open the brush cage and lift out the brushes
I did all that, bought a new brush cage and it is still announcing error 2-clean brushes.
