Ga door naar hoofdinhoud
iRobot Roomba 551 Brushes Replacement
Wat je nodig hebt
  1. iRobot Roomba 551 Brushes Replacement, Side Brush: stap 1, afbeelding 1 van 1
    • Place your Roomba upside-down on a hard surface.
    If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
    David Forrest - Antwoord
  2. iRobot Roomba 551 Brushes Replacement: stap 2, afbeelding 1 van 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Brushes Replacement: stap 3, afbeelding 1 van 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Brushes Replacement, Bottom Plate: stap 4, afbeelding 1 van 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Brushes Replacement: stap 5, afbeelding 1 van 2 iRobot Roomba 551 Brushes Replacement: stap 5, afbeelding 2 van 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Brushes Replacement: stap 6, afbeelding 1 van 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Brushes Replacement, Brushes: stap 7, afbeelding 1 van 2 iRobot Roomba 551 Brushes Replacement, Brushes: stap 7, afbeelding 2 van 2
    • Pinch the yellow tabs on the sides of the brush cage and lift up to open.
  8. iRobot Roomba 551 Brushes Replacement: stap 8, afbeelding 1 van 3 iRobot Roomba 551 Brushes Replacement: stap 8, afbeelding 2 van 3 iRobot Roomba 551 Brushes Replacement: stap 8, afbeelding 3 van 3
    • Grab each brush and lift upwards to remove.
Conclusie
John McTigue
331 Reputatie
3 handleidingen geschreven
Cal Poly, Team 13-14, Regan Winter 2014 Lid van Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Leden
19 handleidingen geschreven
2 opmerkingen
Should be no need to remove the back plate. Just open the brush cage and lift out the brushes
Gunnar Nybraten - Antwoord
I did all that, bought a new brush cage and it is still announcing error 2-clean brushes.
Christa Eads - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 83
Afgelopen 30 dagen: 449
Altijd: 5,970
