Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide explains how to remove the brushes from your iRobot Roomba 551, either for replacement or cleaning.
Onderdelen
Geen onderdelen opgegeven.
  1. Place your Roomba upside-down on a hard surface.
    • Place your Roomba upside-down on a hard surface.
  2. While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Gently pull upwards on the brush to remove it.
    • Gently pull upwards on the brush to remove it.
  4. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Rotate the Roomba upside-down so the bottom is facing towards you.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  6. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  7. Carefully lift the bottom plate.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  8. Pinch the yellow tabs on the sides of the brush cage and lift up to open. Pinch the yellow tabs on the sides of the brush cage and lift up to open.
    • Pinch the yellow tabs on the sides of the brush cage and lift up to open.
  9. Grab each brush and lift upwards to remove. Grab each brush and lift upwards to remove. Grab each brush and lift upwards to remove.
    • Grab each brush and lift upwards to remove.
Conclusie
John McTigue
331 Reputatie
3 handleidingen geschreven
Cal Poly, Team 13-14, Regan Winter 2014 Lid van Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Leden
19 handleidingen geschreven
Should be no need to remove the back plate. Just open the brush cage and lift out the brushes
Gunnar Nybraten - Antwoord
I did all that, bought a new brush cage and it is still announcing error 2-clean brushes.
Christa Eads - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 24
Altijd: 1,288
