Inleiding
The battery is quite simple to replace in a Roomba, and only requires removing the side brush and bottom plate before it can be accessed.
Wat je nodig hebt
Lift and remove the old battery by pulling the tabs on both sides.
Gently replace with a new battery.
6 andere personen hebben deze handleiding voltooid.
If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
David Forrest - Antwoord
