Inleiding
The spinning edge brush is located on the edge of the Roomba. It brushes dirt and hair into the center of the vacuum where it can easily be picked up. If the vacuum is not picking up the dirt on the edge of the vacuum's path, the spinning edge brush may not be working properly.
Wat je nodig hebt
Turn the Roomba upside down, and place it so that the underside is exposed. The wheels and brushes should be visible.
Locate the spinning brush that is directly to the left of the rectangular pocket for the battery pack.
Unscrew the 7.2mm Phillips #1 screw from the spinning brush.
