Ga door naar hoofdinhoud
iRobot Roomba 4160 Brush Replacement
  1. iRobot Roomba 4160 Brush Replacement, Brush Guard: stap 1, afbeelding 1 van 1
    • Make sure the Roomba is turned off to prevent injury.
    • Turn the Roomba upside down so that the underside is exposed. The wheels and brushes should be visible.
    • Identify the brush guard, which is the black rectangular frame that the metal rods are attached to.
  2. iRobot Roomba 4160 Brush Replacement: stap 2, afbeelding 1 van 1
    • Locate the 2 small rectangular yellow tabs on either side of the brush guard, directly adjacent to the blue flap.
    • Place index fingers on both tabs, and apply slight pressure in the direction of the yellow battery pack.
    • While you are applying pressure, the guard should hinge up in the direction of the yellow battery pack.
  3. iRobot Roomba 4160 Brush Replacement: stap 3, afbeelding 1 van 2 iRobot Roomba 4160 Brush Replacement: stap 3, afbeelding 2 van 2
    • After the guard hinges up, lift the guard up and away from the Roomba.
  4. iRobot Roomba 4160 Brush Replacement, Brush: stap 4, afbeelding 1 van 1
    • Remove the wire brush by grabbing it by the yellow plastic part of the brush.
    • Pull the brush upwards until it comes out.
  5. iRobot Roomba 4160 Brush Replacement: stap 5, afbeelding 1 van 2 iRobot Roomba 4160 Brush Replacement: stap 5, afbeelding 2 van 2
    • Remove the rubber spinning brush by grabbing it by the rubber part on both ends.
    • Pull the brush upwards until it dislodges.
Conclusie
noah falck
104 Reputatie
1 Handleiding geschreven
Cal Poly, Team 6-4, Forte Spring 2014 Lid van Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 297
