Ga door naar hoofdinhoud
iRobot Roomba 4160 Brush Guard Replacement
  1. iRobot Roomba 4160 Brush Guard Replacement, Brush Guard: stap 1, afbeelding 1 van 1
    • Make sure the Roomba is turned off to prevent injury.
    • Turn the Roomba upside down so that the underside is exposed. The wheels and brushes should be visible.
    • Identify the brush guard, which is the black rectangular frame that the metal rods are attached to.
  2. iRobot Roomba 4160 Brush Guard Replacement: stap 2, afbeelding 1 van 1
    • Locate the 2 small rectangular yellow tabs on either side of the brush guard, directly adjacent to the blue flap.
    • Place index fingers on both tabs, and apply slight pressure in the direction of the yellow battery pack.
    • While you are applying pressure, the guard should hinge up in the direction of the yellow battery pack.
  3. iRobot Roomba 4160 Brush Guard Replacement: stap 3, afbeelding 1 van 2 iRobot Roomba 4160 Brush Guard Replacement: stap 3, afbeelding 2 van 2
    • After the guard hinges up, lift the guard up and away from the Roomba.
Conclusie
Philippe Napaa
222 Reputatie
2 handleidingen geschreven
Cal Poly, Team 6-4, Forte Spring 2014 Lid van Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 317
