Ga door naar hoofdinhoud
iRobot Roomba 4160 Battery Replacement
  1. iRobot Roomba 4160 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the Roomba is turned off to avoid an electric shock.
    • Turn the Roomba upside down, and place it so that the underside is exposed. The wheels and brushes should be visible.
    • Do not attempt to open up the yellow battery pack. You may get shocked or burned by the battery acid.
  2. iRobot Roomba 4160 Battery Replacement: stap 2, afbeelding 1 van 2 iRobot Roomba 4160 Battery Replacement: stap 2, afbeelding 2 van 2
    • Identify the yellow plastic rectangular battery, directly to the right of the spinning brush.
    • Place your index fingers on the small rectangular plastic tabs on both sides of the battery. Push the tabs in until the battery comes loose.
    • Pull battery out using your fingers.
Conclusie
To re-install battery, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Garrett Rasmussen
225 Reputatie
2 handleidingen geschreven
Cal Poly, Team 6-4, Forte Spring 2014 Lid van Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 973
