Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Lay the Roomba upside down on a flat surface with the blue strip away from you.
Use your index fingers to pull the yellow tabs towards you.
While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
Pull back the brush guard to unhook it from the latches.
Remove the brush guard by lifting it up and out of the Roomba.
Remove the main brush by grabbing it and pulling it up and out of the Roomba.
First, insert the black end of the main brush into the black square opening on the right side.
Second, lay the main brush back into place.
