Ga door naar hoofdinhoud
iRobot Roomba 4100 Flexible Rubber Brush Replacement
  1. iRobot Roomba 4100 Flexible Rubber Brush Replacement, Brush Guard: stap 1, afbeelding 1 van 1
    • Lay the Roomba upside down on a flat surface with the blue strip away from you.
  2. iRobot Roomba 4100 Flexible Rubber Brush Replacement: stap 2, afbeelding 1 van 2 iRobot Roomba 4100 Flexible Rubber Brush Replacement: stap 2, afbeelding 2 van 2
    • Use your index fingers to pull the yellow tabs towards you.
    • While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
    • For reassembly, make sure to push in the brush guard until it clicks into place.
  3. iRobot Roomba 4100 Flexible Rubber Brush Replacement: stap 3, afbeelding 1 van 1
    • Pull back the brush guard to unhook it from the latches.
    • Remove the brush guard by lifting it up and out of the Roomba.
    • This picture has a change in orientation to illustrate the latches. Continue disassembling the Roomba with the blue strip away from you.
  4. iRobot Roomba 4100 Flexible Rubber Brush Replacement, Flexible Rubber Brush: stap 4, afbeelding 1 van 1
    • Set the brush guard aside.
    • The flexible rubber brush is the smooth, all-rubber brush that is closest to the yellow battery.
  5. iRobot Roomba 4100 Flexible Rubber Brush Replacement: stap 5, afbeelding 1 van 2 iRobot Roomba 4100 Flexible Rubber Brush Replacement: stap 5, afbeelding 2 van 2
    • Remove the flexible rubber brush by grabbing it and pulling it up and out of the Roomba.
    • For reassembly, orient the Roomba with the battery closest to you:
    • First, insert the black end of the flexible rubber brush into the black square opening on the right side.
    • Second, lay the flexible rubber brush back into place.
Conclusie
Samantha Barrett
501 Reputatie
5 handleidingen geschreven
Cal Poly, Team 17-5, Forte Winter 2014 Lid van Cal Poly, Team 17-5, Forte Winter 2014
CPSU-FORTE-W14S17G5
5 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 917
